Dymes
Everything posted by Dymes
can i buy a copy from you ?
8P disc is out has anyone got it yet ? :hyper:
Me 2 please !!
I'm interested in your wheel PM me how much you want thanks !!!
Anyone have Chrome Door Handles on Long Period & Still Look Good?
Dymes replied to mistytreasure's topic in 2008 Edge & MKX
I've had mine over a year an still look good !!! -
TO ALL THE HIR & HID HEADLIGHT EXPERTS!!! THOUGHTS???
Dymes replied to dereck's topic in Interior, A.C., Heat, Interior Trim
Amen to that !!! The Lex Edge get it now !!! -
Added Ford/Pioneer NAV to '08 EDGE
Dymes replied to HDedge's topic in Audio, Backup, Navigation & SYNC
Sorry guys I did mean to come off that way because of where I work there are things I cann't talk about an things I see done so thats why I wuz able to get it done.What I should have said is that it is possible to have done but ford has it set up in away that dealer donn't have access to.The rewiring can be done on your own.but if ford see it can void elec' warranty. Sorry again -
I will say this Nav will work an Sync too an not hard to have done some reprograming an jumper wires.Dealer can not do this because of warranty reasons once you touch or alter factory wiring you have voided your electrical warranty there is different wiring that goes in for a nav factory unit.I had my unit done an everything works including sync.Not going to say how so done ask. -
I talk to a tech at the plant today an he said that it can be done.I'm stuck too by friday he is going to flash my set up at work an he said everything should work.If he cann't do it then I know there is no chance this is his job !!
Longer OEM antenna for Ford Edge
Dymes replied to Kanatronic's topic in Audio, Backup, Navigation & SYNC
A friend of mine put an edge antenna on his golf cause he wanted a short antenna an it worked fine !!so I'm guessing it works both ways ? -
VW antenna will fit.. -
LOL just stick your 2 fingers in the little space an pull back like a banana I'll pop right off.
On the top it says pioneer with model number 8T4T..... the sony has something totally different on in I don't have one infront of me to tell to but can find out this week if you like M/T.
The fit is the same only differents is that 09 deck is a sony not pioneer an sirius is built in not a seperate module.There may be a wiring conflict because if you had a cd player with sirius you would have a module in the trunk an you don't need that.The correct Antenna is made to do both approx 190cdn.So if it is a pioneer in your 09 its totally wrong...... Does your steering wheel controls work with it ?
Any update yet I just got the Nav deck also an when I plug it in I have no steer control an no Sub an GPS do you need another anntena for GPS? Going to dealer on weekend to talk to them about it. -
The shifter an base are one piece.Only the grey part with cup holder around it come off an Shifter an base come pre assembled.
Agree !!!
I agree ford knows of the problem an they are trying to fix it an have taken step to correct it, some might say not the best ones but they are try.As an CAW member I can only work with what I'm given to work with engineer must set higher standard for quality on part an out sourcing !!!
Start from where the console storage opens an just pull up lightly they just snap in that it.
Repair guy at the plant said that there a lot better.shape an fit are the same they will fit in 08s
I work on the line in trim area mainly dash install an some wiring stuff.I have the same problem with my edge dealer waiting for parts.I've already changed my drive shaft an hangers (out sourcing bad parts) I only had 11000km on my Edge.I read more here than they tell us at the plant but you see alot too.My friend in repair department gave me the heads up to watch for these problems an he was right ..........
I work at the oakville assembly plant where the edges are built, spoiler are pre ordered an pre wired according to orders, everything is done on the line.Dash comes done to us we just plug them in an bolt them down.
If the wiring is in the trunk it behind the deck as far as antenna if the bubble is on your spoiler your antenna is there tooo....If these thing aren't present in car kit is your best bet.
