THE_BOLT
Everything posted by THE_BOLT
Getting Keypad code from Ford
THE_BOLT replied to jacobson's topic in Alarms, Keyless Entry, Locks & Remote Start
Some factory keypad codes are on the backside of the interior fuse box. To be able to see them could be a challenge for some -
2016 sport 100k and still going....but not for much longer
Engine wants to stall - Code P1450 & P144A - Evap Purge Valve
THE_BOLT replied to shumax's topic in 2017-2018 Edge & MKX
I've went through the steps replacing the purge valve and had the canister replaced....the problem still exists after putting gas in the tank. I'm starting to believe the problem exists in the filler neck....possibly a valve in the caplets system that's not venting correctly -
I had the purge valve and canister replaced...still having the problem after fill ups and I never top the tank off -
How long did your original battery last?
THE_BOLT replied to 1004ron's topic in 2017-2018 Edge & MKX
I live in Michigan -
Yes mine does it. I don't put any more gas in after the pump kicks off when filling the tank. I only run 93 octane, have a catch can, change the oil between 4-5000 mile intervals as I drive 52 miles one way to work mostly expressway, changed the spark plugs twice...I've got around 85000 miles on it currently. Dealer replaced the charcoal canister assembly under my extended warranty this past summer and a few months before that I replaced the purge valve...but the problem still exists. Lately since it's been cold out there has been a couple times when I was at a drive thru it stumbled and made a weird chirping sound almost like a fu**ed up bird...didn't even have a full tank of gas at the time. So I'm lost on what it could be...basically waiting for the engine or turbo to blow and leave me stranded on the side of the road -
Did you ever find out what the issue was -
2016 Ford Edge Intelligent Access
THE_BOLT replied to Teresa30's topic in Alarms, Keyless Entry, Locks & Remote Start
Do you have the headlight knob turned to the automatic on position -
I had the same issue on my 2016 Sport. It would only happen when stopping the first few times after filling up...it acted like it was going to stall at stops. I only run 93 octane in mine also. Tried replacing the purge valve but issue continued. So I took it to the dealer where a friend was a mechanic and he suspected it was purge valve until i explained that i already installed a new one...then he replaced the canister and problem is gone. Now I don't know if you top off to get to the even dollar amount at the pump...which I used to but don't anymore. Reason being is that will cause gas to somehow overflow into the canister which will make it cause issues
Rear Motor Mount (RMM) (2016 Edge Sport)
THE_BOLT replied to snmjim's topic in Accessories & Modifications
I think it softenes up a bit...but maybe you just get used to it lol -
Has that been happening since the engine was replaced?
Airbag removal (adaptive steering model)
THE_BOLT replied to papinist's topic in Interior, A.C., Heat, Interior Trim
The last picture shows the screw i was talking about. If that comes out then that back plastic piece on the steering wheel should come off. Then you should possibly see the release for the airbag. Also the only way to get the steering wheel off is the bolt behind the airbag -
It almost looks like you're going to need to take the 2 torx screws out of the bottom of steering column...might be a tx20 or tx25. After that there are screw holes that at the back of steering wheel which appear to be holding the back cover on. Im sure once you get to that point you'll see more of what you're looking for -
I am curious! I had the dealership replace all drivetrain fluids at 36000 miles when I had it in for warranty work. Now I'm almost at 76000 and going to change them at my buddys shop myself...except the trans fluid I will let him do that since I have no clue how to operate that machine. This time I'm planning on running redline oils in the PTU & RDU. The trans will stay motocraft. You have me curious about how my oil analysis will turn out.
How do you argue that with someone who builds them
Yes. Direct injection until the PCM commands it to spray port side
Seriously the only difference between the 2.7 engine in the F-150 and Edge is intake manifold, throttle body, exhaust manifold and intake tubing...oil pump drive possibly too. Which goes for all the engines! The blocks and heads are drilled and tapped with the same oil galleys, injector holes and so on...unless you have the H.O. EcoBoost engine like in the Raptor. The only reason that everything you read says its for the F-150 is because that's Fords bread n butter.
I'm sorry...as of 2018 all ford EcoBoost engines have dual injection. They call something else like dual fuel
Any direct injection engine will have a problem with carbon build up on the back side of valves. But all EcoBoost engines went to dual injection in 2017...not just the F-150
Actually you are correct. They did go dual injection starting in 2017...which i have to admit im a little jealous since mine is a 16. But after seeing what a catch can collects instead of it going back into your engine...I'm going to basically put one on any vehicle I buy new from here on!
We're not catching oil like your BBQ grill
Lmao! Ravioli can. No! I've got the JLT catch can. Easy install and removal if you're minimally mechanically inclined
Also mine is still under warranty...i take the catch can off before I take it in for warranty work just so they can't give me an excuse to void my warranty
The motocraft semi synthetic is what was made for it so it won't hurt a thing. Its cheaper to buy your own oil and do it yourself...just make sure to stick with the motocraft oil filter
