Summers22
    2
Everything posted by Summers22
  1. O'Reilly says bad battery, going to get it replaced now.
  2. I am using a TopDon Artidiag500. Thats the odd thing, no check engine light. Part of me things it could be a torque converter issue and a transmission drain and fill would help. Google AI says all symptoms point to a bad battery, I did replace it in August of 25 and did the BMS reset with the same scanner.
  3. Trying to help my daughter with her car. Multiple codes, reduced power and very sluggish acceleration up until 40mph. No check engine light. List of codes: ABS Antilock braking system : DTC Description Status U0140:00:20 Lost Communication With Body Control Module CMDTC U0265:00:20 Lost Communication with Image Processing Sensor A CMDTC U2107:00:68 Collision Mitigation By Braking CMDTC U3003:16:60 Battery Voltage CMDTC PCM Powertrain Control Module: DTC U0284:00:68 Description Lost Communication with Active Grille Air Shutter Module 'A' CMDTC
  4. One of the things I absolutely love about my Titanium Elite is the grille. Couldn't imagine swapping it out, but looks okay on yours.
  5. Is everyone here like 80? I am 53 and have no problems using my phone for forums, Instagram, snapchat with friends and family, emails, online shopping, etc.
  6. Do you use this forum on mobile? Its an absolute nightmare with all the pop up ads and search suggestions.
  7. Is there a paid option? Otherwise I'll stick with the Facebook groups as this is like no other free forum I have ever been a part of......
  8. Joined this forum a couple months ago and generally use it on mobile. Why isnthe screen covered 3/4 with adds and pop-ups all the time? Then every search shows a pop up box on the bottom of the screen that I have to click and X to go away. What am I doing wrong? I am logged in. Is there some sort of paid version to make all this junk go away? Overall, the general layout of the forum is the worst I have ever used. Add after add after add, wtf....
  9. I bought an OEDRO from Amazon on sale for $35.99 perfect fit in my 22
  10. Well that didn't work......also my auto start stop reverted back to not working. This is the most finicky vehicle I have ever made forscan changes on....Auto Stop Start eliminator ordered.
  11. You guys that add the ebay/amazon light around the weather seal, show some daytime pics. I have OCD and prefer OEM installs and can't see how a white tube looks good around that seal.....
  12. @Iroga Great, thank you. I also see you have the pano roof. The light fit fine without any interference?
  13. @Iroga did you buy an OEM harness and plug as well as the light? I have a light with backing plate on the way, but need to find a plug or wiring diagram for the 3 pins on the light itself. Thanks
  14. Found it in BdCYM, plain english, search ramp and changed from disabled to enabled.
  15. Dumb request, but on my 23 Bronco Sport, the auto high beams could be set to slowly ramp up brightness. Anyone figure that one out?
  16. Those do look good. A little "bulky" but that is an good option to consider.
  17. Yes those fit, but would look hideous on a Titanium Elite. Plus the price is outrageous...
  18. Its worth a shot I suppose but I highly doubt I'll be happy. I don't mind minor trimming or hole (flap only) drilling but anything more and they'll go back.
  19. I have a 2022 Titanium. My research shows the ST shares the same lower molding. Has anyone successfully fitted mudflaps to the 19up ST or 20up Elite? If so, link please (other than the outrageous Ford branded ones).
  20. It automatically switched back tonthe as-built data, which is confusing to me that it did that, but still took the change.....
  21. @omar302thanks for the help! Interesting observation though. When I went to enter those forscan changes I tried to use all those combinations in the 80s and the program kept telling me that was an invalid choice. It gave me a warning box and stopped at 51% and then I had to restore that code. When I went and checked after doing all that, somehow it must have took because my seat belt warning display is no longer popping up. Have you ever seen anything like that? I kind of know what I'm doing because I've been doing forscan for about 12 years so this is the first time I've ran into something like that. Bambi mode and ASS both took just fine.
  22. Thank you. So those values made it go away, I read it as uou added that feature, my mistake.
  23. Thank you, @omar302 do you know the value to disable the seatbelt location pop-up?
