Wubster100
    26
  1. What do you mean by designation on the part itself? Was ML3T-15K619-JA on the sticker of the part, but ML3Z-15607-K was on the website?
  2. I only have one key, so I will need a locksmith to program a second key. My understanding is that the RTM is not required for programming a key? If the key is programmed correctly, it should be able to start the car using the emergency slot inside of the center console? My plan is to: 1. Save the asbuilt data from my old RTM. 2. Install the new RTM. 3. I should still be able to start the car with my old 300mhz key using the emergency slot. 3. Make the new asbuilt changes to the new RTM and enable remote start. 4. Have a locksmith program the new 900mhz key. 5. Hopefully the new key should work.
  3. I ordered a ML3Z15607G and a 5 button fob even though I don't have a power liftgate. I will find out if it works.
  4. How did you know that the module was from a 2015 Mustang? What did you do to upgrade the firmware? Did you just need to change the asbuilt data or did you need firmware files?
