mikolajczakwh Posted September 26, 2012 Report Share Posted September 26, 2012 Used Ford Edge Throttle Body Spacer Originally 99.95 WILL TAKE 50$ Easy Install takes 15 min Steeda's Billet Aluminum intake spacer is designed specifically for the new Ford Edge. Made from Billet 6061 aluminum it is designed to give you more plenum volume for increased horsepower. The swirl design helps promote airflow by breaking the surface tension of the incoming air. An increase of horsepower and fuel milage can be seen with this part. Kit includes instructions, gaskets and mounting hardware. Note: It is necessary to trim Steeda's Cold Air Kit by 3/4 of an inch if combined with Steeda's Throttle Body Spacer. Product Benefits •Increased horsepower and torque •Increased fuel economy •Simple installation Vehicle Fitment 2010 Ford Edge •2009 Ford Edge •2008 Ford Edge •2007 Ford Edge Used Ford Edge Cold Air Intake w/ New Filter Originally 299.95 WILL TAKE 200$ Steeda's Cold Air intake system for the Ford Edge will give your Edge extra spunk while also helping with fuel mileage. Steeda went the extra mile with its design by allowing it to be used with or without a custom tune. A removable insert is provided which when retained in the mass air meter assembly will allow your Edge to use this intake system on the factory Ford tuning. Removing the insert requires you to use a custom tune for the vehicle to run properly. With or without the insert you can add additional power gains over the intake alone with custom tuning using our SCT Xcalibrator 3 tuners. Expect gains of 10 to 12 horsepower from the intake system alone using the insert and stock tune. The ultimate gains in performance result from the cold air and tune combination. Testing has shown gains of up to 35hp and 27ft/lbs of torque at the wheels when running this system without the insert using a custom tune. Steeda's Edge Cold Air Kit includes a stainless steel airbox with built in velocity stack, billet mass air w/sensor mount, and Pro-Flow Air Inlet Hose. It mounts in the factory location and the stainless steel heat shield features a rubber seal which seals the airbox and isolates it from engine heat. In addition the Pro-Flow Inlet Elbow was designed to accept the factory noise resonator to keep inlet noise to a minimum. A Steeda exclusive! Our lifetime use air filter can easily be cleaned and re-oiled making maintenance a snap. Product Benefits •Lifetime Warranty - Backed by a trusted company that has been in business for over 20 years •Built in Velocity stack compresses and straightens incoming air, eliminating turbulence across the MAF for greater gains than just having larger MAF housing and better throttle response. •Included heat shield isolates air entering the filter from engine bay air reducing air inlet temperatures resulting in better power. Unshielded kits lose power in real world conditions due to reduced air charge density and timing reduction by the computer •Securely mounted to vehicle - Will not vibrate, bend or cause damage like unmounted systems •Increased fuel economy Vehicle Fitment •2010 Ford Edge •2009 Ford Edge •2008 Ford Edge Quote Link to comment Share on other sites More sharing options...
LBE Posted March 7, 2013 Report Share Posted March 7, 2013 On the throtle body spacer: Did you notice any difference? Quote Link to comment Share on other sites More sharing options...
Aj Franchitti Posted March 7, 2013 Report Share Posted March 7, 2013 I am interested. I will keep u posted if funds go thru. Lol Quote Link to comment Share on other sites More sharing options...
ironmattgod1307 Posted July 17, 2013 Report Share Posted July 17, 2013 edge throttle body spacer . I WANT IT MAN . HOW DO YOU WANT ? Quote Link to comment Share on other sites More sharing options...
