Changing wallpaper
chiriru
New Edge Limited owner. Still figuring out how everything works. I have tried and tried to change the wallpaper on the navigation screen and I just don't know what I'm doing wrong. I have added and saved pics from my flash drive and I am pretty sure they are the correct size. I was told they should be 800x384. Has anyone else had this issue before? I would definitely appreciate any help with this. I can't find anything to help in the owner's manual.
Thanks ahead of time! :)
I had a little bit of trouble with this too but figured it out. You have to make sure the pictures are the right size. I cropped the image I wanted to use and saved it as a new file. Then put it on the flash drive and uploaded it to Sync. That worked for me.
You might want to try changing the image quality if you can, to get the file size down.
