Collision Warning Not Available Sensor Blocked Error
Betteh13
My 2013 Edge keeps showing Collision Warning Not Available Sensor Blocked error on my dash. What do I need to do to stop it? I do not see anything behind the facia cover near the drivers side of the lower grill area. I called 2 dealers - the one I purchased it from and another Ford service shop in the area and neither one has any idea how to fix it.
HELP ~ I can not fully use my cruise control until I get it fixed.
Edited by Betteh13
If you don't see anything blocking the sensors then you could try disconnecting the negative battery cable for a few minutes. Otherwise you'll have to take it to the dealer. They can't diagnose it over the phone.
And please don't post multiple times for the same problem.
