Help - Replacing 12V port with 2.1 Amp USB
2011 Edge Sport. Pulled my useless 12V socket and am replacing it with a dual USB port socket. This simple mod has a hiccup and I am pulling my hair out.
Where is the fuse for this "power point"? It is on the passenger side below and to the left of the glove compartment. Manual has fuse listings for 3 power points (console rear, inside console, and cargo area) but this is no where to be found! Ideas?
Too easy Norm :) . Really, I wanted a clean look that would run a black, iPhone cable under the MFT and to my phone. Since I have an iPhone 6, I really wanted to use the 2.1A as it actually loses battery when plugged in and the screen is running an app like Waze throughout my trip. Could certainly pull that off with an adapter, you are correct.
I was making it harder on myself, but wanted more of a built in look. Who uses those things for much else than USB anyways?
