Replacement parts
swalker
My son was climbing into the car a couple weeks ago and he pulled on the turn signal arm snapping the end off. It still works and I was hoping it would just pop back on, but one of the little clips that holds it on broke. My question is, does anyone know if you can just replace the end cap or do I need to have the entire signal arm replaced? If I need to replace this, is it something I can do myself or will I need to take it to the dealer?
Also, just before that my wife broke the cover off the cigarette outlet under the console on the passenger side. Not a big deal, but anyone know how much it would cost to replace that?
Should be able to find the entire switch for around $100.00 or less with a little bit of checking. The replacement is pretty easy and straight forward. There are videos showing Ford products that will give you a good idea of how to do it. Just search on YouTube of Google.
