Two broken door latches on same vehicke. will not open from inside
chip@wuppa.com
2010 edge sel had door latches fail.two in one vehicle. $1000 to fix. Has anyone else experienced this? To add insult you can try fixing yourself but the inner door panel cannot be removed without cutting them off. All eight bolts simply spin due to fasteners behind the panel. I can't believe they would manufacture such poor quality!
