2008 Edge Speedometer stops working
Mtyler
Sounds like the camshaft position sensor (CPS/CMP) might be AWOL. Pull codes to check, there should be something set, and quite likely check engine lights as well. Codes will be P03xx. Any major auto chain store can pull the codes for free.
BTW, did the SPEEDO stop working or the TACHOMETER?
Edited by WWWPerfA_ZN0W
