raymill53 Posted December 12, 2015 Report Share Posted December 12, 2015 I drained some fluid from reservoir tank as coolant was rated for only 10 below zero. but now the tank is above the full mark while engine is cold. Is one on the hoses (two at the top, and one larger one at the bottom) a drain tube? Looks like they all run back to motor or radiator. My question is should I remove some fluid or will it just drain out? Thanks! Quote Link to comment Share on other sites More sharing options...
