Approach Detection/Welcome Mat Lighting Inoperative – 2016 Lincoln MKC
2016 MKC – Approach Detection/Welcome Mat Lighting Inoperative – Built On Or Before 7/22/2015
Some 2016 MKC vehicles built on or before 7/22/2015 can exhibit inoperative Approach Detection/Welcome Mat lighting.
Reprogram the Body Control Module (BCM) to the latest calibration using release 97.02 or higher.
Make sure you are connected to the internet when entering module programming to obtain the latest updates.
Calibration files may also be obtained at www.motorcraftservice.com
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
