FS: Full Air Ride Kit (Accuair and Air Force)
connoisseurr
I have the following air ride components available for sale:
Accuair Endo CVT 5-Gallon 4-corner in Black Cerakote
Has brand new power leads, brand new mounting feet. Was installed inside vehicle for 8 months (May 2019 through December 2019). Comes with an analog compressor adapter.
$1350 SHIPPED
Accuair Elevel with Touchpad and Rocker. Comes with all original wiring, 4 sensors, some extra sensor rods, and a TON of extra fittings for installation. The leads from the main ECU harness have been fitted to a deutsche for easy installation/removal. Vehicle-end deutsche connector can be repinned if any existing wiring needs to be extended (power and ground are cut to about 24”; remote and dimmer are full length. Was installed inside vehicle for 8 months (May 2019 through December 2019).
$950 SHIPPED
Air Force Air Ride setup for Ford Fusion and Gen 2 Ford Edge. Includes front strut pillowball hats. I’m including all brackets for mounting on Ford Edge (rear applicable only needed; front struts fit perfect). All original accessories included. Extra airline will be included for installation. Was installed on vehicle for 8 months (May 2019 through December 2019).
$1400 SHIPPED
Edited by connoisseurr
