50/50 Yellow Coolant
TheBurdman
Hi guys,
New to this forum out of Toronto, Canada. Just did my water pump on my 2015 and all the timing chain componets. I am selling two 3.78 liter jugs of Ford Motocraft Coolant. The jugs are actually concentrate but I mixed the jugs to 50/50 with distilled water. Unfortunately, I prematurely mixed it. I did a flush with distilled water and determined that not all the water drains when doing a flush so adding a 50/50 mix with the water leftover in the heater core and block would throw off the percentage so I needed to add concentrate instead.
I'm asking $15 for each jug. A jug of premixed 50/50 coolant is about $35 at the dealership. I have a tester you can use if you want to check the ratio. Also, this coolant replaces the orange coolant that had issues. The yellow coolant is also backwards compatible.
I also have all the old timing components that were replaced if interested. Vehicle has 122k on it.
The jugs and timing components  would have to be picked up at my home near Canada's Wonderland.
Edited by TheBurdman
