Pedal Commander to smooth light acceleration from stop
My 2019 Titanium AWD 2.0 Edge with 47,000 miles has rough takeoff from stop using normal throttle application. The 8-speed trans isn't helping, shifting every couple of seconds but I don't think that's the issue and I've had the firmware upgrade of the transmission. It helped a lot but I still feel the low-degree acceleration from stop should be smoother. If the car was old and had a conventional cabled throttle I'd look for a broken motor mount.
I'm wondering if a Pedal Commander or something like it would address this issue. A side benefit would be reducing the turbo lag when hammering the throttle to get out of some idiots way but the real issue is the stumbling throttle at what I used to call 'tip-in' but the term doesn't seem to be used any more.
Thanks for your input
Tom
