Stability control problem after change ABS module
jeferson
Hello, I’m having a problem with stability control, after change the ABS module (full module) I can’t turn on the stability control, o tried with obd and using the left screen on the cluster. Anyone knows if there is another step to take related to the stability control after change the ABS?
thank you.
