spencer young Posted November 17, 2022 Report Share Posted November 17, 2022 hello i bought a 2013 awd with a rear end problem. the rear differential carrier for this model is available used for pretty cheap, and fairly plentiful. i didn't realize until after i bought it that my manufacture date is kind of tough to figure out for interchange on this part. my date is 9-12...the 2013 rear diffs i'm finding all specify that they fit through 7-12...even calling the dealership parts dept it's pretty unclear about what with fit my manufacture date. does anyone know why this is? thanks! Quote Link to comment Share on other sites More sharing options...
Slinger Posted November 19, 2022 Report Share Posted November 19, 2022 I also want to know the difference. I am looking for a diff for a later 13 edge sel with a bulid date of 07/13. Let me know if you find a used later one Quote Link to comment Share on other sites More sharing options...
sheshe24 Posted July 28 Report Share Posted July 28 seems to be quite a common problem. i have a 2013 ford edge sport 134000 mi on it, manufacture date is 10/13. the dealership just told me the rear diff is going out. so I'm searching everywhere for one online, all the genuine oem ford websites says its backordered but seem to agree on the part # 9E5140000AC. in a lot of the searches it says through 7-29-12. so that's where the confusion for me is coming in, since it was manufactured after that date. do they mean current date backwards to 7-29-12? Quote Link to comment Share on other sites More sharing options...
edjunior Posted July 29 Report Share Posted July 29 Welcome to the forum sheshe. I can't help with your issue, but I just wanted to let you know, in case you didn't see it, that you are replying to a thread that is 3 years old, and both of those folks had only 1 post. So you may not see a reply from them. It may be better to start a new thread for your issue, though in this case, someone may come along that may be able to help. Again, welcome to the forum. Quote Link to comment Share on other sites More sharing options...
sheshe24 Posted August 8 Report Share Posted August 8 (edited) just fyi. dealing with same problem. purchased part # 9E514000AC. i have a 2013 ford edge sport awd manufactured 10/13/2013. OE/OEM Part Number 9E514000AB, 9E514000AC, ZZD027100, ZZD027100A DOES NOT FIT ford edge manufactured AFTER 07/29/12. i don't care what dealerships say, what ebay says, or anyone else. it absolutely will not work.(if u do happen to purchase one on ebay and use the guaranteed fit and it doesn't, ebay covers return costs.) you need: OE/OEM Part Number S-154-A DT4W-4000-AB fits anything manufactured AFTER 7/30/12 2013 Ford Edge Limited Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge Limited Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SEL Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SEL Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SE Sport Utility 4-Door 2.0L 1999CC 122Cu. In. l4 GAS DOHC Turbocharged For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge SE Sport Utility 4-Door 3.5L 3496CC 213Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Ford Edge Sport Sport Utility 4-Door 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 EDGE Rear Axle, from 07/30/12 2013 Lincoln MKX Base Sport Utility 4-Door 3.7L 3726CC 227Cu. In. V6 GAS DOHC Naturally Aspirated For a 2013 MKX Rear Axle, from 07/30/12 Edited August 20 by sheshe24 more info Quote Link to comment Share on other sites More sharing options...
