RPGR90s Posted 1 hour ago Report Share Posted 1 hour ago 2019 Edge ST with 105k miles Recently the check engine light came on and my scanner revealed the two error codes. Since the purge valve solenoid is right on top of the engine, I thought I would replace this first. Dorman 994-073 Vapor Canister Purge Valve I tried clearing the codes but my cheap scanner won't allow me to do that, so I was hoping the codes would clear themselves, assuming the purge valve is now working. I have also cleaned and inspected the fuel filler area, but it appeared very clean and tight. I would also like to inspect/replace the charcoal canister but I cannot find it's location. If anyone could tell me, I would be most appreciative. Thank You!! RPGR90s Quote Link to comment Share on other sites More sharing options...
