fastfords4me Posted October 1 Report Share Posted October 1 Hi. I have a 2015 Edge Sport. Currently has 210,000 miles. The other day I noticed a large oil slick under the front end. Upon inspection I found the front right shaft seal leaking lube. I removed the shaft and seal. After removing the seal I found small fragments of a bushing lying in the inner tube. I have purchased all the replacement parts but I'm a little stumped with this bushing. It almost will slide into the inner tube but not quite. I slid it down the shaft to check the fit on the journals. It of course passes over the seal journal and seems to fit pretty snugly on the next journal. I'm preparing to slip the bushing in the freezer for a bit to see if it contracts any but it doesn't really appear metallic to me. Has anyone else replaced this bushing or know the correct installation procedure? Thanks In Advance Quote Link to comment Share on other sites More sharing options...
fastfords4me Posted October 2 Author Report Share Posted October 2 Update: I was able to use a 15/16 deepwell socket to align the bushing into the inner shaft. Then placed a metal disc standing on edge in front the bushing. I could then use a length of pipe against the disc to drive the bushing into the inner shaft. Sounds pretty sketchy but worked out okay. Quote Link to comment Share on other sites More sharing options...
