sloney Posted September 24, 2009 Report Share Posted September 24, 2009 Have the Dealer's figured out and fixed the Vista roof rattle yet? Anyone had this issue? Quote Link to comment Share on other sites More sharing options...
securinu Posted September 25, 2009 Report Share Posted September 25, 2009 yeah its a TSB thats been out almost 2 years reglue the trim around the rear glass. Quote Link to comment Share on other sites More sharing options...
securinu Posted September 25, 2009 Report Share Posted September 25, 2009 TSB 07-16-11 08/20/07 ROOF OPENING PANEL SQUEAK/RATTLE FORD: 2007 Edge LINCOLN: 2007 MKX ISSUE Some 2007 Ford Edge and Lincoln MKX vehicles equipped with a roof opening panel may exhibit a rattle or squeak from the rear glass area. This may be caused by the delamination of the rear trim ring hook and loop (Velcro) adhesive. Inspect the rear trim ring and if loose, determine if the loop tape has delaminated from the plastic trim ring. ACTION Follow the Service Procedure steps to correct the condition. SERVICE PROCEDURE If delamination of the hook and loop has occurred, use the following procedure to correct the concern. If no delamination has occurred, follow normal Workshop Manual (WSM), Section 100-04 diagnostics. 1. Remove rear trim ring per WSM, Section 501-17. 2. Inspect all loop tape locations for delamination. (Figure 1) 3. Remove all delaminated loop tape from module. (Figure 2) 4. Clean trim ring attachment surface with a Isopropyl Alcohol or Rubbing Alcohol (IPA) wipe (Figure 3). 5. Allow surface to dry. 6. Apply Motorcraft® Instant Gel Adhesive to trim ring surface. (Figures 4 and 5) Apply loop pad to trim ring. (Figure 6) 8. Allow adhesive to dry per Motorcraft® Instant Gel Adhesive recommendation. 9. Reinstall trim ring to vehicle per WSM, Section 501-17. 10. Clean roof opening panel glass with Motorcraft® Ultra Clear Spray Glass Cleaner or equivalent. WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part. Parts Block OPERATION DESCRIPTION TIME 071611A 2007 Edge/MKX With Roof 0.4 Hr. Opening Panel: Reapply Loop And Pad To Trim Ring, Includes Time To Remove And Install Trim Ring, Clean Glass DEALER CODING CONDITION BASIC PART NO. CODE 7050036 24 Quote Link to comment Share on other sites More sharing options...
