PTU LEAK
BURR
I know several of you have had leaks from the POWER TAKE OFF UNIT (TRANSFER CASE). Mine was leaking at the front pass side axle. They put a seal kit in but it's still leaking. Going back in monday for another fix. Have many of you had the unit replaced with a new ne or just a seal kit fix?
May depend on when you originally had it fixed. I had a 2008 and had the seal replaced spring of 2010. I was told that they had just improved the seal and it should not go bad again. Replacement seals previous to that were also bad and many people have had them replaced multiple times. Not sure how much truth there is to this, just what I was told.
Okay took awhile. The PTU was on national backorder. They put in a new one this week and now their is a small transmission leak where the unit joins the transmission. Will take in tuesday to try and get this taken care of. I don' know about a TSA or not but could ask.
Here is the TSB I was referring to.
http://way2evil.com/tsb/tsb09-25-07.pdf
I had my PTU replaced in September of 2010, and I'm not sure if the part itself has a warranty on it or not. You may want to check.
My leak may be due to a big temperature change, so I've cleaned the PTU and I'm going to keep checking periodically. It wasn't that big of a leak, but knowing that this is a problem made me freak out a bit since my power train warranty is out.
  • 4 weeks later...
