Thomas c Posted October 17, 2015 Report Share Posted October 17, 2015 Can not turn off emergency flashers. Even disconnected the battery. When I reconnected it they turned back on.Has this happened to anyone else? What do I do? Quote Link to comment Share on other sites More sharing options...
macbwt Posted October 17, 2015 Report Share Posted October 17, 2015 The switch needs to be replaced. Disconnect the switch or replace it. The touch switch tends to fail apparently from other posts made on this forum. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted October 17, 2015 Report Share Posted October 17, 2015 (edited) If the hazard button/switch is capacitative, it could indeed be the culprit as mac said. You can get a hard button switch now I think instead so the problem is less likely to recur. The other possibilities could be wiring and/or a fault in the BCM. If there are no other symptoms, these causes are highly unlikely. Link to example of new panel with hard button: http://www.fordedgeforum.com/topic/18249-hazard-warning-lights-turn-on-by-themselves/?do=findComment&comment=136790 Edited October 17, 2015 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
