Clunk with low speed left hand turn>
  • 4 weeks later...
2007 MKX. Clunk when turn turning left 90 degrees, or 180 degrees. Low speeds(AKA stopped at a stop sign, start rolling forward, then turn wheel).
Anyone else have that?
TSB 07-25-8 is for the clicking or creaking cv joints.
They can check but if its a early production 2007 and some 2008 vehicles, then there are other known problems when making a 90 degree turn at slower speeds.
The ABS brakes will apply rather abruptly . There is a cure for this but it takes a bunch of coordination with Ford Tech line
to get it approved etc.
Some vehicles will require that the ABS control module located on the Hydrulic control unit ( HCU) be replaced.
Richard and Barbie
Edited by BlueLtd
