Everything posted by sajid.ali
Disable door keypad
sajid.ali replied to Polecatt's topic in Alarms, Keyless Entry, Locks & Remote Start
There will be a connector (as shown in Pic) on the back of keypad which can be accessed by opening the door Panel. -
Sorry didn't get you. What to check?
Check the tyre pressure, on both LHS tyre, pressure is 25Psi, didn't understand
Keyless Entry Keypad-Ford Edge SE-2013
sajid.ali replied to sajid.ali's topic in Alarms, Keyless Entry, Locks & Remote Start
It enters into the programming mode but didn't learn any thing, either a new IKT or Keyless Entry Keypad -
Remote start will not start car
sajid.ali replied to mgl79's topic in Alarms, Keyless Entry, Locks & Remote Start
May be Hood Switch is faulty, you can check it by putting a piece of wire in the connector to short the two terminal and give a remote start signal.. -
Tried, its not working -
Agreed. The programming method provided along with the keypad is not working. Although ford website says that it is compatible with ford 2013 non peps models. I have also checked with the local dealer here in Saudi Arabia but they even don't know it. -
Gary, i got ur point and fully understand how to program a new IKT or PATS key through IDS. My main concern is to program the Ford wireless entry keypad, which is a genuine ford accessory and ford says that it si compatible with Ford Edge 2013 Non PEPS vehicles . -
Realize after posting the comment to check the inflation level of each tyre...
Thanks Waldo, any idea, how to catch the culprit?
got it, any idea at what pressure Low tyre pressure warning will come?
what is the recommended tyre pressure for 18" (245-60R18)?? At what pressure, TPMS warning will come out? Last month tyre pressure warning appear in my car, upon filling the air to the required pressure, warning goes off, but 2days ago it comes again. To me its seems to be some other problem than inflated tyres. Any expert opinion?
CL3Z-19G364-B ---------- > for Edge / MKX with Push Button Start CL3Z-19G364-A ---------- > for Edge (A) without Push Button Start & Without Power Lift gate ( without Push Button Start & With Power Lift gate Anybody noted the difference in the Kit components? I have searched out Ebay for CL3Z-19G364-A but i didnt found it. Will it fit to Edge without Push button & without power liftgate? Remote Start Apps Chart.pdf
Remote Start Kit Series 200 - Short Range
sajid.ali replied to rsucre's topic in Alarms, Keyless Entry, Locks & Remote Start
Same issue with me also, i have installed 100 Series Plug n Play Remote Start Kit to my 2013 SE. Ford is claiming a range of 300ft but unfortunately it is working only in a range of 30-40ft. -
I love to but it seems that language is Arabic and unfortunately i canot understand Arabic to that level, you can post your issued here.
Yesterday i have noticed another thing that i have tried to program a new Integrated Key Transmitter (IKT-comes with the Remote Start Kit) in the same way mentioned above but it also fail. Although i have Enabled the Owner Key Programming feature thriugh IDS. Any ideas folks?? I really need help on it -
still trying and searching..... any idea how to know the frequency of the RF Keypad? -
Stick On Keyless Entry Pad
sajid.ali replied to Mr. Westfield's topic in Interior, A.C., Heat, Interior Trim
through IDS Keys will be programmed by putting key into the ignition in ON position and pressing "Program Button" in IDS, there is no option i have found to program the kaypad. -
I have checked it comes with 433Mhz but dont know the frequency of RF Keypad.. -
Creaking noise coming from drivers side b-pillar
sajid.ali replied to jlong's topic in Interior, A.C., Heat, Interior Trim
I have an SE-2013 model and facing the same issue.... -
Omar, This need to be investigated.. any idea how to find out this infor. Thx -
Yes, I am pressing both buttons at the same time and releasing them. also it light up when i press the buttons. Will it require any programming through IDS?? I can do that if required.
