When I hit the CD button on the player (Not Navi) it displays CD error. It will not eject CD's, or accept them. I figure the deck is done or jammed? Anyone else had this issue?
I am guessing it just the cover for the mirror harness. The mirror before build date Nov 29/2009 contains a microphone for sync/bluetooth. The rest of the wires are for the compass and auto dimming feature
If you have to tow package, you have two outputs to the fans. I have looked into the service manual and cannot find anything regarding the tow package fans. So, if don't have the tow package and one fan is not working, then you have a bad fan most likely.
Have the fuel at 3/4 of a tank or less. Remove the rear seat and access cover. You need a special wrench or something to remove the lock nut on the fuel pump module. Lift out carefully and remove the fuel jumper tube on the inside.(AWD models) Then voila. So pretty easy if you have the right tools.
Yeah, got one off ebay. First one didn't work, so sending it back. Got a 09-10 edge factory service manual. I prefer them, because they give you proper DTC trees.
Just got the factory service manual for 09-10, which is basically the same as an 07-08. Works great. Lots of good info. http://www.ebay.com/itm/181544453007
It's not rocket science. Oil is oil. It has to be changed at some point, it can only absorb so many contaminates before the lubricity factor is null. You can easily suck it out with a 20$ oil pump.
Most rear differentials don't have drains, does that mean you wouldn't change it if the dealer said you didn't have to? Just use some common sense!
Still looking for a factory service manual for the edge. Bought one off ebay, but it only includes the OBD diagnostics for a 2007 edge, and not the workshop manual. I will be returning it. Downloaded a torrent for 2007-8 ford manuals, and same thing. Does anyone have a copy or info on getting one? Thanks
