Per the vendor of the Vista Roof Panel, do not use lube.  System should be dry.  Most likely, the panel tracks are too tight.  " Open roof and look inside of track. You will see bolts holding track. Just crack bolt,don't loosen off to much. Take a screw driver and lightly tap track over slightly. Tighten bolt repeat on next 3 bolts!"
