Everything posted by rvcjew
On the turn signal stalk do you have a button on the end, and if you press it do you get a car with lines on either side show up in the left side of the Cluster? Also since you are feeling this issue on turns while making a turn that you know it can repeatably be done on and when safe to do so turn on your turn signal in the direction of the turn to disable the system if it is enabled and see if anything changes. https://owner.ford.com/how-tos/vehicle-features/safety/lane-keeping-system.html Malcolm
I also think the new wheel will be the correct fix, I have over 4,000 on mine now without issue. Malcolm
It seems to be a over time tolerance issue with the gears inside the wheel itself so they have revised the design internally and also I believe updated some software as well. For some they just got a revised clock spring but and I think they are okay but some came back from that so they went back and just fixed the core issue of the wheel itself I guess. FYI: My wheel was replaced and is same on the outside but my down arrow on the left side controls is a little finicky while my original wheel was perfect. I was not gonna fight them on this though as the wheel works fine and tracks fine. Malcolm
New Wheel. Malcolm
rvcjew replied to jmr061's topic in Audio, Backup, Navigation & SYNC
Good to hear you got it done. Malcolm -
If using the MAC, format the flash drive as FAT in disk utility (it will format it as fat32 but apple calls it this). The car will say updating and then it will show in the top black section only a picture of a update icon I believe till it's done. I did it a while ago so don't fully remember but it should show a message without a prompt then begin then show a message with a prompt at the end. Should be like this: (That video shows for non nav but the update part is the same as it will show you what it does while updating) https://www.youtube.com/watch?v=p1TjdhDdkxg?t=232 Malcolm -
Looks like it's operating properly yeah. I will look at what mine gets next time I use AA. Should not show anything till its done. I started the car stuck in my flash drive it said it was gonna update then I drove for around 30 minutes and it said done and to turn off the car so I did and made sure to open the door so sync shut off then waited 5 minutes to turn the car on again and then drove around for another 10 minutes till the nav portion came back. Taken from the zip: READ ME THIS UPGRADE IS FOR NORTH AMERICAN 2016 FORD/LINCOLN MODELS WITH SYNC3 V1.0 OR V 1.1 FACTORY NAVIGATION ONLY. THIS WILL UPGRADE FROM VERSIONS 1.0/1.1 TO VERSION 2.2 YOU WILL NEED A FAT32 OR EXFAT FORMATTED 2GB OR MORE USB FLASH DRIVE USING A WINDOWS BASED COMPUTER UNZIP THE UPGRADE FILE TO THE ROOT FOLDER OF FLASH DRIVE YOU WILL END UP WITH AUTOINSTALL FILE AND SYNCMYRIDE FOLDER IN THE ROOT OF THE USB DRIVE TAKE FLASH DRIVE TO YOUR VEHICLE AND REMOVE ANYTHING PLUGGED INTO THE USB PORTS START YOUR VEHICLE AND INSERT UPGRADE FLASH DRIVE UPGRADE PROCESS WILL BEGIN AND TAKE APPROXIMATELY 15-20 MINUTES ONCE UPDATE IS DONE (A MESSAGE WILL APPEAR) YOU MAY REMOVE THE FLASH DRIVE AND TURN THE VEHICLE OFF LEAVE THE VEHCILE OFF FOR APPROXIMATELY 5 MINUTES AND RESTART YOU WILL SEE THAT YOU NOW ARE RUNNING VERSION 2.2 THE BUILT IN NAVIGATION MAY TAKE SEVERAL MINUTES TO START BACK UP THIS IS USED AT YOUR OWN RISK AND YOU TAKE ALL RESPONSBILITY FOR ITS USE NAVIGATION MAPS DO NOT GET UPGRADED WITH THIS UPDATE Malcolm -
Mobile site double post. -
No, that is the charge rate with screen off. My discharge is normally with screen on at around 150mA with 3 emails and some other push stuff. Also I read Lildiscos charge rate as 3xxx not 2xxx so their charge rate is fine but I'm wondering if aa is not letting their phone go in a low power STATE or if they have some kinda wack add app in the back ground. I agree a car ride may not charge the turbos battery (3900mah) all the way but should not discharge it. Malcolm -
I'm more interested in your discharge rate, also when it goes black and says the letters the screen then after like 10 seconds just shuts off right and the phone sleeps while using AA? That is a pretty high charge rate if accurate though, I hit about 1920mA with the screen off (won't charge that quick with screen on as designed). -
Ah, Quickcharge requires the charger to have a chip that can communicate with the phone. I for instance charge my LG V20 with the samsung QC 3.0 charger from my old note 7 (LG one has electrical noise under load). It is only rated at 2.0 amps at 5 volts, you can charge with as little as 2 no problem but you still need that chip communication. Is your screen staying on while using AA? https://www.qualcomm.com/products/features/quick-charge/faq EDIT: Also my car does not quick charge my phone, but will charge it faster than it can drain while using AA, and it will get kinda hot as expected. 2nd Edit: Lildisco get Ampere to see what your device is charging at. https://play.google.com/store/apps/details?id=com.gombosdev.ampere&hl=en Malcolm -
Lildisco what phone do you have? Is it quickcharge 3.0? Malcolm -
Hi all: I want to open my front driver and passenger Sport Cooled/Heated seats, but just the back if that is possible. I'm trying to see if the seatguru fix for the cooled function will work in this seat but the directions are for the F150 and they have a zipper on the back that the edge does not seem to have. http://seatguru.wixsite.com/fordseatfix/instructions If some one knows what clips need to come off to get to this part of the seat I would be grateful, I plan on taking detailed pics if I do the fix. Malcolm
Hold the left side OK button while starting the car keep it held till a prompt appears in the left side then release and go up and down for the different screens, you want the dtc screen. It has thngs to test the gauges ect. Don't change any of the things farther down as it might reset your fuel meter ect. I don't believe you can hurt the car with any of that though. It's self explanatory in each screen. Good luck.
I would just while you know it's not working go into the engineering mode and take a picture if you have any dtcs. That way you have proof when you get home.
Is this bad or you just stating that it is available? -
Just read the thread from page 17 onward. On mobile can't quote right. Both of those links for the file are fine. -
I used a MBR FAT32 flash drive with no issues. Good Luck. Malcolm EDIT: my mega gave me a warning so maybe my link is messed up. @Ray Health Jr also has this link if mine is broken: https://drive.google.com/file/d/0Bxlap1Uv4Q55NnhBMjdEaUtfZms/view -
Good to know also, also I found out anyone who wants that tach back its in settings/display where it never was before it and is defaulted to off. I was hoping to get the tsb done for airbag soon do you happen to have the number of it? I only got a letter stating it would be Q2. Malcolm
I agree, They should not have removed any of them I never used it but they really should just have a menu to tick off the ones you don't want so you only have to scroll though the ones you need. I would much rather have mine have nothing but the circle tack with gas and heat (why is this the only one with water temp!), air pressure, and speedo. And if you could also rotate in the trips that would be good to. I don't need a gimmicky menu showing where torque is atm. Just my opinion. Maybe you can ask them to not wipe the vertical tach when they put on the new wheel?
It was one of the rotatable screens just under my display right, if so I think it is indeed gone for me. Malcolm
I did and they just programmed it again and it was all good. I also have an option to disable the lift gate switch which I swear was not there before. I also notice the vertical tack that was useless is now not an option as well and only the circle tack remains. http://www.fordedgeforum.com/topic/21044-adaptive-steering-fault/page-15?do=findComment&comment=165397 Malcolm
It is used by databases to look things up quickly or in this case to make sure you have a non corrupt file to flash to your Sync 3 system. https://en.wikipedia.org/wiki/Hash_function https://en.wikipedia.org/wiki/SHA-1#SHA-0 I personally use this Shell extension to check them on my machine if your using windows. http://code.kliu.org/hashcheck/ Malcolm -
Thanks for letting me know the hashes are very important though. Malcolm -
Make sure you have the same hashes when downloading and here is my link. https://mega.nz/#!GhZRyDgb!AAM04HkOIQK4Rq89gUffnOB95vCSNvQOyyq5tubBUss . Make sure to follow the instructions. Malcolm
