AkMan13
Everything posted by AkMan13
Supersixmotorsports.com has cams for the 3.7 at $1400. I wanted to see how it would sound before dropping that kind of cash on the edge. My exhaust consist of gutted cats, still have the mid muffler/resonator, and pipe to replace the muffler in the back. Running the ghost cam would simulate what a 3.7 with cams would sound like. As for the popcorn tune, i don’t get the pops and crackles i would like so i wanted to get a tune for it. I’ve heard retarding ignition and stopping the ECU from cutting fuel right after decel would help with that.
Hello , i was wondering if anybody has done some custom tuning ? I was told the 3.7 in the edge sport has the same twin-independent variable cam timing as the 3.7 in the mustang. This would allow it to be able to run a “ghost cam” also was wondering if anybody has experience was pops and bangs on their tune also know as a popcorn tune or tommy gun tune. This is where the tuner retards ignition and stops the ECU from cutting fuel after decel. This is all assuming you don’t have cats. As they could mess them up if you have them and run this
Is it a mistake to purchase OEM size tires (22)?
AkMan13 replied to Cedarburger's topic in Wheels & Tires
As promised here are the 20x10 fathom stern wheels. Tires are Toyo proxes st3 . I actually ended up getting another set of tires which are 275/50R20 . These look great , no spacers, no rubbing just the slightest of poke. Great handling so far and just today i have gotten a handful of compliments. Definitely way more than the oem wheels which people thought were aftermarket due to the size. I still have them but might sell them to make up some cash back. -
Ijoy has these on amazon for $116 https://www.amazon.com/dp/B00M8L65JE/ref=cm_sw_r_cp_api_i_tpZeFbSTVSEVP
i know this is an old post but does anybody have a link to these or a good set of fogs. Was initially thinking of just putting some flood lights and running a rocker style switch to the dash but these look great as well !
Oh I absolutely understand. Where i live there isn’t much fog . Mostly open country roads. The lightning out here at night is horrendous. Not many street lamps. This isn’t something I’ll be running 24/7 but definitely thought I’d be a cool look to add some real bright lights and integrate them into the grill or something.
I also like the flush look but spacers we’re actually not mine . I borrowed them for 2 weeks from a good buddy of mine. Just wanted to see how it would look . -
i only have pictures of the old set up after the lowering springs. I will have some pictures taken this weekend by a buddies new camera ! The wheels are Fathom Stern 20x10 with 38mm offset. I picked them up from bbwheelsonline.com. The tires are Toyo Proxes 295/40R20. No rubbing for me. I do have spacers so they poke just a little bit. Might take them off and see how it runs without them. -
Don’t apply to what ?
Not sure if anything has changed much since this post but i just came across it and i have done a couple of things to my 13 sport. 1)k&n cai 2) bbk 73mm throttle body 3) fuel injectors for e85 (600cc) 4) thermostat to keep engine temps cooler 5) h&r lowering springs 6) custom exhaust (axle backs) 7) Tune
Hello . I have a 2013 Sport Awd. i have switched mostly all my lights in the interior and exterior to led. I’ve always wanted fog lights on my edge but unfortunately it only came in the drl. Which are mediocre at best. I was wondering if anybody has installed some fog lights on their vehicles and if so how they wired it. I’m not looking for spotlights or anything like that . I’m looking for something i can switch out the bulbs to some super bright led. Not sure if it makes a lot of sense but the vision i have is definitely a great look. I was thinking i could maybe cut some of the lower grill to install the fogs.
I was debating going smaller for a while now. I just bought a 20x10 wheel with a 295 wide tire. Weight was cut in half on each corner and they ride amazing. Definitely s lot more peppy and about 3mpg more -
Paired with the tune i have , e85, lowering springs, bigger tb, ported intake manifold, colder thermostat, and a few other goodies :)
Hello, I’m aware this is an older post but yes there is quite a bit of aftermarket support for the ford edge. I have a tuned 3.7 , k&n intake, fuel injectors for e85, lowering springs from h&r, colder thermostat, and an exhaust. you also mentioned hid , i bought mine from a company called innovated on amazon. Really good pair of hid kits. Have lasted me quite a while now
i know this is an older post but i lowered my edge and switched out the factory 22 with a 20x10 wheel. Sits nice
i have k&n intake in my edge. Huuuge difference. Could really hear that thing sucking up the air at WOT.
Yeah i have this issue as well . I have the awd sport and when i press the button after fueling, it seems like it turns over but doesnt actually want to turn on. It happens every single time i fill up with gas. It takes at least two times of trying to turn over for the engine to start. Not the battery in my situation because I’ve replaced it 200miles ago
i have a 2013 ford edge sport awd. I haven’t had transmission issues but have noticed 17mpg on city drives and 20mpg on highway with cruise control on.
I have 2013 edge and all i did was cut the mufflers off and weld in some pipe. Definitely sounds a bit louder
Yeah I’ve heard great things about the ecoboost. I was actually looking into the new explorers , now those are beauts !
Might be true , not expecting a race car but will definitely leave people scratching their heads haha ! Anything done to yours ?
It’s been years since a post here.. but i have a 2013 Ford Edge sport awd. I’ve done a tune with torrie over at unleashed tuning as well as a k&n intake. I’m wanting to know about more 3.7 mustang parts that’ll fit the edge. I’m interested in switching over to E85. Talked to my tuner and they said it’s possible with a few modifications (fuel pump, lines, and injectors).
I see.. well being that it’s the 3.7 found in the mustang, would it be possible to switch some things over ? I was talking with my tuner and they said i would be able to get onto e85 with a few modifications (fuel pump,line, and injectors). I don’t know why but I’ve always loved that police interceptor explorer look and wanted to get some 18in steelies for it and get it on different tires. Being as the current 265/40R22 arent exactly the smoothest or eco friendly out there.
Awesome! Thanks , i don’t have a facebook but will be creating one today to look them up. Thanks again yeah we looked into the trailers from uhaul as well lol , definitely excited to move out
