Sarnano Posted June 11, 2012 Report Share Posted June 11, 2012 I just had Uhaul install a trailer hitch on my 2011 Edge. Should there be a heat shield above the rear muffler on the '11? I've seen older posts discussing modifications of the heat shield to fit the hitch. I suspect that my installer did not re-install the shield, since I don't see anything there. Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 11, 2012 Report Share Posted June 11, 2012 There are heat shields on both sides Quote Link to comment Share on other sites More sharing options...
Sarnano Posted June 12, 2012 Author Report Share Posted June 12, 2012 ..... thanks. I know their are 2 heat shields for th 2010 and older, but the 2011 has a single muffler. I just want to make sure it was equipped with a heat shield before i chase down Uhaul Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 12, 2012 Report Share Posted June 12, 2012 Well I know our 2011 has two but we do have two mufflers. This variation in the muffler design is what can make hitch fit an issue. Maybe someone that has a single muffler can confirm. Quote Link to comment Share on other sites More sharing options...
cjd3 Posted June 13, 2012 Report Share Posted June 13, 2012 I was checking my exhaust area because I too will be installing a hitch. And yes, there are 2 heat shields, one on each rail, on my single muffler 2012. I would be livid if they forgot to put them on mine. Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 13, 2012 Report Share Posted June 13, 2012 Very strange...I don't even remember taking mine off. I am pretty sure I just used tin snips with it mounted. Not sure why they would have removed it to begin with. Quote Link to comment Share on other sites More sharing options...
Sarnano Posted June 13, 2012 Author Report Share Posted June 13, 2012 (edited) Well, as I write this the Uhaul shop is re-installing the 2 heat shields. I call them yesterday and the mechanic said "You don't need them anyways". Then he was quick to offer to reinstall them. Amazing. The guy knew he was wrong, and got bagged! The factory installed them for a reason is my feeling. Good thing I checked.... I was curious to see how the hitch was mounted, and noticed the shields were missing. I knew somehthing was wrong because I reviewed a video af few days back (pondering doing the job myself) showing the installation, and the trimming of the shields. Edited June 13, 2012 by Sarnano Quote Link to comment Share on other sites More sharing options...
wlepse Posted June 13, 2012 Report Share Posted June 13, 2012 Good glad you are getting it straightened out without too much hassle. Quote Link to comment Share on other sites More sharing options...
