amp install
For those of you who have installed an amp, did you run the power cable and rca cables down opposite sides of the car? I've mostly heard it varies based on the quality of the cables you have. In my last car, I installed cheap components found at walmart. Ran all cables down the passenger side but experienced noise, so I rerouted the power cable down the driver side and the interference noise went away. This time around, I will be installing quality components with a JVC amp and Knukonceptz amp install kit
