How Remove Dash Stereo on Ford Edge 2015 For LockPick
Hello I have a new Ford Edge 2015 Titanium, I wont use LockPick MyTouch Air for unlocked in Motion.
I use before in My Grand Cherokee 2011 Limited and never use a car with out LockPick.
I look but find nothing on the Internet and Youtube.
I am able to switch the Top of the screen, the middle but also not able to remove the bottom. everything is in a block.
I not want to broken any parts in my new Car.
Thank You in Advance.
I don't know, Where you see the Video for installation on 2015 Ford Edge.
I see only that of a 2015 Ford Escape.
My problem is that I want to remove the Dash Ford Edge 2015 with nothing broken.
I know how I installed the Lockpick is my third model.
Thank You.
  • 2 months later...
The same old video from their site will work for your Edge
I followed it without any issues, it's very easy!
The issue you might have, I have encountered, which the two clips behind the gearstick get's stuck.
Just get a small flathead screwdriver, and gently try to push the clips away, this will require another person to help out and hold the part as you the rest from behind.
I hope you didn't get confused there :)
Q. How's the screen clearity for the Air mirroring ?
I've tried it on my LG G3 and iPhone 6, and both suck. I'm about to get a replacement...
