GLASS FOGGING OR SLOW TO CLEAR – MANUAL HEATING AND AIR CONDITIONING SYSTEM – BUILT ON OR BEFORE 2/7/2014
TSB 14-0062 (supersedes TSB 14-0048)
Publication Date: March 26, 2014
FORD: 2014 Edge
This article supersedes TSB 14-0048 to update the Action Statement.
ISSUE:
Some 2014 Edge vehicles with a manual heating and air conditioning system and built on or before 2/7/2014 may exhibit glass fogging or slow to clear after the defrost has been engaged.
ACTION:
Reprogram the Heating Ventilation Air Conditioning Module (HVAC)/Remote Climate Control Module (RCCM) to the latest calibration using IDS release 89.03 and higher. Calibration files may also be obtained at www.motorcraftservice.com.
OPERATION DESCRIPTION TIME
140062A 2014 Edge: Reprogram The HVAC/RCCM And Clear DTCs (Do Not Use With Any Other Labor Operations) 0.2 Hr.
WARRANTY STATUS
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
DEALER CODING
BASIC PART NO. CONDITION CODE
19980 04
Ford Module Programming (FMP) is a software application that allows subscribers to program electronic modules on Ford, Lincoln and Mercury vehicles. It can be used for:
•Reprogramming emission-related (OBDII) modules on some vehicles manufactured in 1995 and all vehicles manufactured from 1996 to the present
•Reprogramming or reconfiguring non-emission-related modules on many vehicles (UBP and MS-CAN not supported)
In addition, module initialization (PATS) functions such as Keycode Erase/Reprogram and PCM Parameter Reset can be done using this application.
J2534 Device using Ford Module Programming (FMP) can Reprogram and Configure most Modules.
