Agima Posted September 14, 2016 Report Share Posted September 14, 2016 Keeping my keys attached to my Ford Edge's Key fob, I was tired to trigger the panic button once in a while. I didn't want to disable the panic button itself, so.It's not 100% proof, yet it seems to be quite effective so far.Step 1: Take a small paperclip like this and remove one of the stainless steel pin. Step 2: Open your key fob for a better access and drill two small holes on each side (You can see one hole in the picture). Step 3: Reassemble you key fob, insert the stainless pin's small edges into the holes of the key fob, and voilà, a quick, cheap way to prevent the problem from occuring again! 1 Quote Link to comment Share on other sites More sharing options...
