Cv axle replacement
APL111
Hello
I need to replace the cv axle on the drivers side on my 08 edge awd. I have never done this but I am proficient with working on cars. I have the shop manual and have looked at youtube videos but cannot figure it out. On the side that goes towards the PTU there is clip on the splined shaft how does one remove this to get the unit out. I know the other end is held by the hub bearing. Thanks alot for the help.
Tony
Hello
Tony
Clip removal pliers will do the job.
Oh, I got you. There is a round clip ring on the end which locks it into place. Usually, a pry bar will get that end out but use caution not to go crazy cause there is a bushing there. If at first you can't remove it, rotate that end like 1/8 or a revolution and try again, move and try again. The lock ring has a slight opening and you are trying to match the small opening with one of the spline grooves. Good luck
