Dash Cam Install w/ Parking Mode
cmantis
I recently installed a dash cam into my 2016 Edge Sport using a 2 wire kit and tapping into Fuse #23 (Delayed Accessories) as per a guide I found here.  However I want to re-wire it to enable parking mode with a 3 wire kit.  Basically ground and then one wire to a switched fuse and one to a constant on fuse.  I am using the fuse panel up under the drivers side - does anyone have any advice one which two fuses to tap into for this?  Thanks in advance.
