2012 Edge Cooling Fans And A/C Stuff.
A/C cools nice while car is moving (87 here in Orlando) if I stop and idle for a few minutes ac compressor turns off.  Car started overheating today while in a car wash line.  I let it cool down for about 10 minutes and the coolant temp went back to normal.  Drove it home with no stopping and it did fine.  I swapped the cooing fan relay with an identical one we never use(Rear window defroster LOL)   Anyway neither cooling fan comes on at all.  Do I need to replace the whole cooling fan unit or is there something else to test that might isolate the problem?   Thanks!
Can't you just ziptie or ducttape it in place?  Or are the wires/pins coming loose in the connector?  If you have enough mileage on your Edge, you may be looking at a fan assembly replacement anyway.
Closest thing I have found is this
https://www.rockauto.com/en/catalog/ford,2011,edge,3.5l+v6,1446671,electrical-connector,radiator+fan+motor+connector,2556
So I am sure the exact connector you need, if not this, is out there.
  • 4 months later...
