System Check reports Oil Pressure Low
CarCat
Re 2008 Ford Edge Limited with all power features including Message Center. (Just bought this vehicle, have no prior experience with its power features. High mileage going on 180K)  Have found System Check in the Message Center. Owner's Manual reads to have ignition in Run position to use Messeage Center but says nothing about having the vehicle running when Message Center cycles through System Check. "Oil Pressure Low" was the only item with a negative report.  Engine cold and off when I ran System Check. Question:   In order to get an accurate report, Is the engine supposed to be running when System Check is performed?
