RedSinglet Posted July 15, 2022 Report Share Posted July 15, 2022 I have a 2013 Edge, just got the driver's headlight replaced and noticing that when I start the car after several hours/day the turn signal on this headlight does not work. After driving for a bit, it starts to work and function normally. I can start the car back up in a few minutes and everything still works as intended. Any ideas what could cause behavior like this? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 17, 2022 Report Share Posted July 17, 2022 Sounds like it likes to work after getting heat soaked. I'd start by changing the light bulb. Check the wiring connector when you have it out. Also have a look at the wiring for any cuts or tears. Quote Link to comment Share on other sites More sharing options...
