Help me figure out my Edge Codes (Ford Edge 2018 SEL)
pr1ncemani
Hi. So, I've been having my check engine light on for some time now, so I decided to run a scan through the FORScan tool. Attached below are the DTC codes it found. Can you explain me what the hell is going on and if there is an easy and inexpensive way to permanently fix the PCM code? I don't wanna go to the dealer uninformed and they try to rip me off if the problem happens to be much simpler. Also, please note that I recently had the purge valve replaced as the car was undergoing a hard-start after every refuel. That problem is solved but the check engine light is still on.
Any and all help will be appreciated.
Thank you.
edge_17052023_DTC.txt
