Wubster100 Posted April 1, 2025 Author Report Share Posted April 1, 2025 8 hours ago, RapidRedSD said: brake bleeding was super simple About how much DOT 4 LV did you use? Quote Link to comment Share on other sites More sharing options...
RapidRedSD Posted April 1, 2025 Report Share Posted April 1, 2025 I purchased 2 12 fl oz bottles. You’ll lose a bit changing out the abs module then you’ll want to make sure you keep the reservoir full during the bleeding process. 1 Quote Link to comment Share on other sites More sharing options...
shopey456 Posted January 15 Report Share Posted January 15 Hey guys, I don't know if this was mentioned earlier or even if this thread is still looked at, but is the CCM harness prewired? I've got a Titanium that I plan to retrofit ACC but I am still trying to figure out how difficult it would be and what parts I need.(Most of which I have gathered in this thread) 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted January 15 Report Share Posted January 15 You need to make the harness from under the left head light to the center of the bumper. 4 wires. positive, negative, Can+ and Can-. The two CAN wires should be twisted. 18 or 20 gauge for the power is more then enough. If I had to do it again I would use a Cat5 wire. Use one of the pairs for the CAN. I would use a twisted pair for each power wire. For example: Blue Can+ Blue/White Can- Orange and Orange/White Positive Brown and Brown/White Negative This is an easy, but time consuming job, if you have experience with electrical work and basic mechanical skills. However, this is not a beginner project. You can do a lot of damage to the front bumper and wiring harness if you are not careful. 1 1 Quote Link to comment Share on other sites More sharing options...
shopey456 Posted January 16 Report Share Posted January 16 Ok, I figured it would be pretty time consuming having to take the front off. @Wubster100, I saw you mention that a possible FW flash to the radar might be needed if it is pulled from a non-edge; do you have the documentation on doing the flash? My yard has a few vehicles with the same part # that I'm (hopefully) going to be able to source the radar from. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted January 22 Author Report Share Posted January 22 (edited) I started doing some research, and there appears to be many models that the radar could be pulled from that look compatible like Explorer, Ranger, Mustang, F-150, F-250, Transit, Transit Connect, Navigator, Aviator, Corsair, Nautilus, and more. The firmware flash, if needed, is probably easiest with FORScan, an extended license, and a quality supported adapter. And also a battery charger. Edited January 22 by Wubster100 Quote Link to comment Share on other sites More sharing options...
