2016 Ford Edge DTC C1001 Backup Camera
Welcome to the Forum @rdavis006!
Echoing @Wubster100, from the 2016 Workshop Manual's final step of the Rear Camera installation procedure:
  • Follow the instructions on the scan tool to configure the rear view camera.
If  Rear Only Parking Aid Camera
LIN Communication
The BCM and the rear parking aid camera communicate via a LIN circuit which is a dedicated single wire communication network.
The messages sent from the BCM to the camera are:
  • Camera configuration data
  • Display manual zoom request
  • Guideline on/off request
  • Trailer connection status (if equipped with trailer tow)
  • Steering angle
  • Standby enable/disable request
The messages sent from the camera to the BCM are:
  • Camera status
  • Display zoom status
  • Camera part number data
  • Guideline status
If  Front and Rear Parking Aid Cameras
LIN Communication
The IPMB communicates with the front and rear cameras via a LIN circuit, which is a dedicated single wire communication network.
The messages sent from the IPMB to the front and rear cameras are:
  • Camera view request (front camera only)
  • Display manual zoom request (rear camera only)
  • Guideline on/off request (rear camera only)
  • Steering angle (rear camera only)
The messages sent from the front and rear camera to the BCM are:
  • Camera status
  • Display zoom status (rear camera only)
  • Guideline status (rear camera only)
Per your original request: 2016 Edge Rear Camera partial diagnostic Pinpoint Test, with connector pinout and Battery Junction Box (BJB) fuse location...
DTC Charts: APIM
Pinpoint Test A (Partial)
A9 CHECK FOR VOLTAGE TO THE REAR CAMERA
  • Ignition OFF.
  • Disconnect Rear Parking Aid Camera C4357.
  • Ignition ON.
  • Measure:
    Positive Lead Measurement / Action Negative Lead
     C4357 Pin 1 imagen2.dll?id=E141493_EUR&w=99&t=JPG  Ground
Is the voltage greater than 11 volts?
Yes GO to A10
No INSPECT BJB fuse 23 (15A). If the fuse is OK, repair the circuit for an open. If the fuse is not OK, REFER to the Wiring Diagrams manual to identify the possible causes of the short circuit.
BatteryJunctionBox(BJB)-FuseF23Red-Boxed-2016Edge.thumb.jpg.99be078b9ed9993ee01455a3e1a52ee0.jpg
A10 CHECK FOR GROUND AT THE REAR CAMERA
  • Measure:
     C4357 Pin 1 imagen2.dll?id=E141493_EUR&w=99&t=JPG  C4357 Pin 5
Yes GO to A12
No For vehicles with an 8 in (203 mm) touchscreen, GO to A11
For vehicles with a 4.2 in (107 mm) centerstack infotainment display, REPAIR the circuit.
Good luck!
Edited by Haz
  • Thanks 1
Thanks guys for the reply I did try the LIN Module intialization. The procedures aborts and tell me to run self diagnostics test.  Ran self diagnostics on BCM the only in BCM is DTÇ B115E.  I have checked the connectors behind trim of lift gate they all look fine. I believe next step is pin test?
