kkelleher Posted April 15 Report Share Posted April 15 i have a 2014 ford edge awd with v6. i just got it smogged 4 days ago and today i had a warning light come on for low oil pressure, its throwing codes p0012 and p0022 both cam sensor banks over retarded. after a min or two running i hear like a squealing or grinding coming from engine. I'm just trying to see what is the most common problem with these issues are. I doubt both cam sensors go out at the same time 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 17 Report Share Posted April 17 Welcome. The low oil pressure will make the Variable Valve Timing inactive and throw the codes that you have. The low oil pressure and noise you describe makes me think the engine is trashed. What's the mileage? What's the service history, oil change interval? What oil and oil filter used? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 17 Report Share Posted April 17 The only common problem that I can think of with these engines is the internal coolant pump leaking coolant into the oil - that would also result in a low oil pressure (cant pump the water). What's the oil look like? 1 Quote Link to comment Share on other sites More sharing options...
