chisle Posted April 18 Report Share Posted April 18 Ford Edge 2013 SEL FWD 3.5L with Sync2 + NAV I find the 'touch' action on the center console rather a distraction when driving. Often I need to look down to make sure I'm touching the correct button for comfort (heat/cooling, etc.). It would be so much easier to do this without looking if they were actual buttons, as in most other vehicles. Does anyone know of a center console replacment that has buttons instead of the touch? 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 19 Report Share Posted April 19 (edited) Edited April 19 by Wubster100 1 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted April 20 Report Share Posted April 20 (edited) Welcome to the Forum @chisle! As you describe your 2013 Edge SEL, it should be equipped with the optional SYNC with MyFord Touch, including the features highlighted below in yellow... The expanded vocabulary of 10,000 Recognized Voice Commands includes the ability to control various HVAC functions via spoken words... hat Hopefully, you becoming proficient in the most useful of these Climate Control Voice Commands can eliminate your need to replace the Center Stack Control Panel and also reduce the distraction it has represented. Attached below as PDF documents are several references that may be helpful... Good luck! Climate Control Voice Commands - SYNC2.pdf MyFord Touch - MyLincoln Touch Supplement - Printing 4.pdf 2013 Ford Edge Source Book.pdf 2013 Ford Edge Quick Reference Guide.pdf Edited April 20 by Haz 2 Quote Link to comment Share on other sites More sharing options...
chisle Posted Wednesday at 12:32 AM Author Report Share Posted Wednesday at 12:32 AM Thank you! I will look into the voice option. Seems the SE console improves little over the SEL for what I'm trying to accomplish, so we'll leave it there. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted Wednesday at 12:45 AM Report Share Posted Wednesday at 12:45 AM As @Haz also mentioned above, you can use the steering wheel switch to adjust the climate control in the instrument panel cluster. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted Wednesday at 02:43 AM Report Share Posted Wednesday at 02:43 AM Excellent addition, @Wubster100! Good luck! 2 Quote Link to comment Share on other sites More sharing options...
