Steering issue
Try and follow this and understand if you can, just this week I have noticed on my 22 SEL, 31,000 miles, that when going through a lengthy left curve in a road at 40-45mph, the steering will want to stick left like it is wanting to lock and you have to pull the wheel back right as you're going to the curve in the road.  You can feel it in the steering wheel when it happens, like it is catching, its not tire related.  Very odd.  Steering response is perfect otherwise.  I have an oil change interval coming up and will have Ford put it on the rack to look it over, but they can never find anything I have an issue with.  Thanks!
Took the Edge to the dealer last evening, they gave me a loaner Bronco Sport to drive, 51 miles on it, pretty sweet Outer Banks, way more loaded than the Outer Banks I use to own.  Anyway, we'll see what they say about the steering issue when they get it tested.
Dealer telling me there are voltage issues that could possibly be causing the steering issue, I had to go to the dealer and drive it with the service advisor yesterday, it did it for him.  Tech said it was pulling left really bad also, I let go of the wheel 3 times with the service advisor in the vehicle, it never left the lane or wanted too.  They drove it again after I left and said it was pulling left, could be related to the catching sensation in the wheel when going through a left curve in the road.  See what happens when they reset the BMS and anything else electronic today.
