danwdc Posted August 24, 2025 Report Share Posted August 24, 2025 Is there a way to mostly drain the coolant system? I remove the drain plug and reservoir cap and only half comes out. Is there a bleed screw? I think it’s only on the 4 cylinder. Would an evac kit like this get it out? https://a.co/d/98lJ9b8 I can get a vacuum pump from O’Reillys but I can’t figure out attachments to evac the coolant. Or is it just drain fill repeat, drain fill repeat… Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 26, 2025 Report Share Posted August 26, 2025 Its been my understanding that you usually only get around half the coolant because the other half in still in the heater core and engine block. I've read where some remove the lower radiator hose and get a little more. Vacuum drains work in some cases, never heard whether it works on the 3.5. Usual way is to refill with distilled water, drive, drain and refill again. But I've always heard that changing half is usually sufficient. Personally, I wouldn't worry about it. Ford doesn't. Quote Link to comment Share on other sites More sharing options...
danwdc Posted August 26, 2025 Author Report Share Posted August 26, 2025 Thanks for the reply. I was thinking about the lower radiator hose. But I figured “why?” since the petcock is lower than the lower hose. Quote Link to comment Share on other sites More sharing options...
NzP Posted October 14, 2025 Report Share Posted October 14, 2025 I plan to do it also. I think to drive, get the thermostat open and apply some pressure using a reservoir cap with a fitting and connect an air inflator to it. 1 Quote Link to comment Share on other sites More sharing options...
