mjm917 Posted 13 hours ago Report Share Posted 13 hours ago I have been doing a bit of Google Fu as i prep to change the coolant myself for the first time. A couple of videos I’ve watched talk about opening the coolant bleeder vale to purge the air. I however seem to be blind as i do not see it – supposedly it is located near the thermostat Can anyone confirm if the 2011 does indeed have a bleeder valve. if there isn’t one, what is the best way to bleed the system after refilling. TIA Quote Link to comment Share on other sites More sharing options...
