BraddB Posted October 12, 2025 Report Share Posted October 12, 2025 The other day my wife's 2013 Edgedecided to be difficult. My wife came home from work and it was raining outside, she said that neither the front or back wipers or washer would work. I ASSUMED this would be an easy fix, just replace a fuse or relay and they would work as they should once again. Well, we all know whathappens when you ASSUME something. I started off by replacing all of the fuses under the hood related to the wipers... no luck. Next I checked the relays, ALL of the relays, still no luck. At this point I decided to order and replace the wiper switch. This didn't help either. I am at a loss and ready to blow this car to Kingdom Come. Do any of you have any ides or suggestions before we have to spend big bucks and take it in to the dealership? Any help getting this figured out would be greatly appreciated. 1 Quote Link to comment Share on other sites More sharing options...
Bowlingman Posted October 22, 2025 Report Share Posted October 22, 2025 I'm experiencing the exact same issue. It's as if no power is getting to the control assembly on the steering column. It had been several months since I last turned the wipers on. My problem started about a month ago. Have you gotten any feed back on your issue? Have you had to resort to a trip to a Dealer? If I get resolution, I'll reply to this post. Thanks. Quote Link to comment Share on other sites More sharing options...
BraddB Posted November 11, 2025 Author Report Share Posted November 11, 2025 On 10/22/2025 at 5:53 PM, Bowlingman said: I'm experiencing the exact same issue. It's as if no power is getting to the control assembly on the steering column. It had been several months since I last turned the wipers on. My problem started about a month ago. Have you gotten any feed back on your issue? Have you had to resort to a trip to a Dealer? If I get resolution, I'll reply to this post. Thanks. I haven't gotten any feedback as of yet, but I had a shop scan it and it came back being a bad "wiper control module". I haven't had it fixed or even priced yet so I don't know what to expect as far as cost to get it fixed. I will keep you updated, although I'm not too sure when we will get around to fixing it, hopefully in the next couple of weeks. Quote Link to comment Share on other sites More sharing options...
