RPGR90s Posted 22 hours ago Report Share Posted 22 hours ago I have a 2019 ST with 93k miles. I thought the auto trans had a dipstick so I removed the air box. All I see is a rubber sort of clamp that I would expect to be where the dipstick is. I removed it and it definitely gives access to the inside of the tranny. So I grabbed a very long thin screwdriver, inserted it, but didn't see any evidence of fluid. I know it has fluid as it runs and shifts fine, so I have a couple of questions. Is there a way to check the fluid level? Is there a fluid change interval? Is there a drain plug? What is the quantity after a fluid change? What is the recommended fluid and amount? Thanks very much!!!! 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 21 hours ago Report Share Posted 21 hours ago 51 minutes ago, RPGR90s said: Is there a way to check the fluid level? The transmission must be warmed to operating temperature. Confirm the temperature with a scan tool. The vehicle must be level. Use the transmission leveling plug on the side of the vehicle. 52 minutes ago, RPGR90s said: Is there a fluid change interval? Change every 30k miles. The owners manual shows intervals. 53 minutes ago, RPGR90s said: Is there a drain plug? Yes, there is a drain plug, fill plug (the rubber vent that you removed), and a leveling plug. 54 minutes ago, RPGR90s said: What is the quantity after a fluid change? There is no specific quantity. You must overfill the transmission, then use the leveling plug to drain excess fluid. 55 minutes ago, RPGR90s said: What is the recommended fluid and amount? Mercon ULV / Valvoline Mercon ULV equivalent. Do not use anything else, such as Mercon V or LV. 57 minutes ago, RPGR90s said: I thought the auto trans had a dipstick so I removed the air box. All I see is a rubber sort of clamp that I would expect to be where the dipstick is. I removed it and it definitely gives access to the inside of the tranny. So I grabbed a very long thin screwdriver, inserted it, but didn't see any evidence of fluid. There is no transmission dipstick. DO NOT insert anything into the transmission other than the fluid. See these threads: Quote Link to comment Share on other sites More sharing options...
