thrdrl Posted November 21 Report Share Posted November 21 Hi All, 2011 Base model. All key fobs for door lock/unlock stopped working. I was unable to reprogram them (I am familiar with the procedure and have done it several times on Mustang and Grand Marquis). Fob batteries new, car battery two years old and on a battery tender. Wife took car to Batteries plus and they were able to reprogram one fob and sold her a new keyless fob. Now, a month later, no fobs work. I suspect it is the module. I see these are commonly sold used on eBay for around $40 and are supposedly located behind the passenger side kick panel. Does anyone have any experience in this module replacement? Does it need any special programming or can I just plug it in and reprogram the fobs? Thanks in advance for any advice. -Mike Quote Link to comment Share on other sites More sharing options...
thrdrl Posted November 23 Author Report Share Posted November 23 Problem solved !! I read an article suggesting to try disconnecting the car battery for an hour to reset the module and it worked. Fobs working again. 1 Quote Link to comment Share on other sites More sharing options...
edjunior Posted November 23 Report Share Posted November 23 Great. Glad you got it solved. And thanks for posting back with the fix. This helps others that may be having the same or similar problem. Quote Link to comment Share on other sites More sharing options...
